<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can Security Monitor Pro give a notification or alert when the network is unavailable?]]></title><description><![CDATA[<p dir="auto">I have set Security Monitor Pro for monitoring overnight. I see that my ISP has maintenance or downtime randomly at night. Is there a way to get an alert or notification on network failure?</p>
]]></description><link>http://nodebbtest.deskshare.com/topic/22582/can-security-monitor-pro-give-a-notification-or-alert-when-the-network-is-unavailable</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 05:26:54 GMT</lastBuildDate><atom:link href="http://nodebbtest.deskshare.com/topic/22582.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 May 2016 06:19:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can Security Monitor Pro give a notification or alert when the network is unavailable? on Tue, 17 May 2016 10:15:37 GMT]]></title><description><![CDATA[<p dir="auto">Yes, <a href="https://www.deskshare.com/video-surveillance-software.aspx" rel="nofollow ugc">Security Monitor Pro</a> can play an alarm when a network failure occurs. Under General settings there is an option ‘When network failure occurs, turn on audio alarm’. Select this option.</p>
<p dir="auto"><img src="https://www.deskshare.com/forums/images/posts/SMPpost5053.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">From the drop down list, you can select the length of time to run the alarm.</p>
<p dir="auto">Alternatively, you can use multiple monitoring stations on different ISP's to make sure recording occurs. Please see this article on <a href="https://www.deskshare.com/resources/articles/smp_MultiplePCs_Backup.aspx" rel="nofollow ugc">multi-station surveillance monitoring</a>.</p>
]]></description><link>http://nodebbtest.deskshare.com/post/36033</link><guid isPermaLink="true">http://nodebbtest.deskshare.com/post/36033</guid><dc:creator><![CDATA[DeskShare_-_Support]]></dc:creator><pubDate>Tue, 17 May 2016 10:15:37 GMT</pubDate></item></channel></rss>
