<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What is the PRET command for FTP?]]></title><description><![CDATA[<p dir="auto">Hello…<br />
I am trying to connect to server but unable to do so. After doing some search I found like it needs some PRET command to make connection. Can anyone explain what PRET command is? And when it is required?</p>
]]></description><link>http://nodebbtest.deskshare.com/topic/22527/what-is-the-pret-command-for-ftp</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 19:53:29 GMT</lastBuildDate><atom:link href="http://nodebbtest.deskshare.com/topic/22527.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 24 Feb 2016 06:24:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What is the PRET command for FTP? on Wed, 24 Feb 2016 11:32:24 GMT]]></title><description><![CDATA[<p dir="auto">When you are talking to a distributed FTPS server, it needs a PRET command to be issued before all calls to PASV. PASV doesn't work with standard FTP and distributed transfers. The client sends a PRET (PRE Transfer) command before PASV to inform the server what kind of command/transfer will be used.</p>
<p dir="auto">In <a href="https://www.deskshare.com/ftp-client.aspx" rel="nofollow ugc">Auto FTP Manager</a>, you can connect to the server using active mode. If you are connecting to the FTP server using the Active mode, you must set your firewall to accept connections to the port that the FTP client will open. Most Firewalls block those incoming connections so you need to configure your firewall to allow active mode connections.</p>
]]></description><link>http://nodebbtest.deskshare.com/post/35978</link><guid isPermaLink="true">http://nodebbtest.deskshare.com/post/35978</guid><dc:creator><![CDATA[DeskShare_-_Support]]></dc:creator><pubDate>Wed, 24 Feb 2016 11:32:24 GMT</pubDate></item></channel></rss>
