<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MPEG-2 to WMV Question]]></title><description><![CDATA[<p dir="auto">Hello, love the program!</p>
<p dir="auto">I am wanting to convert videos that are in MPEG-2 format, 720 x 480, 29 fps and put them in WMV format.</p>
<p dir="auto">My goal is to make the file smaller and to utilize the metadata features of WMV files (can add comments, etc. for better playback in Windows Media Player.)  But I don't want to lose the quality of the image.</p>
<p dir="auto">I'm trying to use the WMV for Desktop Playback as recommended in this forum.</p>
<p dir="auto">When I do that, the output is slightly choppy and the image seems stretched vertically.  Almost as if it converted it to 640 x 480.</p>
<p dir="auto">Is there a way to keep that same aspect ratio and also trim down the choppiness?</p>
]]></description><link>http://nodebbtest.deskshare.com/topic/21749/mpeg-2-to-wmv-question</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 03:08:21 GMT</lastBuildDate><atom:link href="http://nodebbtest.deskshare.com/topic/21749.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Jul 2007 13:40:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MPEG-2 to WMV Question on Mon, 09 Jul 2007 22:02:20 GMT]]></title><description><![CDATA[<p dir="auto">MPEG 2 files include a setting telling the player what aspect ratio to use -- that is, the shape of the image during playback.  WMV files do not.  Your MPEG file is probably meant to play back at the 4:3 ratio of most TV sets and computer monitors.  When the video is converted into a 720x480 WMV, it plays back at a different ratio and looks stretched, as you say.</p>
<p dir="auto">To fix this, convert the files using the "WMV - for desktop viewing" setting, and click the Properties button.  On the Properties tab, select "DVD Quality Video (2 MBPS CBR)".  For the "Encoded BitRate" select "2000 kbps 640x480".  Converting to a 640x480 image will produce a WMV file that plays back without stretching, and the very high quality setting should eliminate any choppiness.</p>
]]></description><link>http://nodebbtest.deskshare.com/post/35099</link><guid isPermaLink="true">http://nodebbtest.deskshare.com/post/35099</guid><dc:creator><![CDATA[DeskShare_-_Support]]></dc:creator><pubDate>Mon, 09 Jul 2007 22:02:20 GMT</pubDate></item></channel></rss>
