<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Noise from speakers]]></title><description><![CDATA[<p dir="auto">When I key 'Start Preview' a noise comes from the computer speakers. I can't see why this noise needs to occur, and can't find out how to suppress it without turning off the sound which I don't want to do while I am learning how to use the system.</p>
<p dir="auto">I am going to the States for a month. Can anyone set me off in the right direction for monitoring the security of my home from there, please? I will be taking a lap-top with wireless card, and an Orange mobile.</p>
<p dir="auto">Many thanks</p>
]]></description><link>http://nodebbtest.deskshare.com/topic/21457/noise-from-speakers</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 19:54:10 GMT</lastBuildDate><atom:link href="http://nodebbtest.deskshare.com/topic/21457.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Jan 2005 18:58:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Noise from speakers on Sat, 08 Jan 2005 19:50:45 GMT]]></title><description><![CDATA[<p dir="auto">The noise occurs when you place the microphone next to the speakers. This is usually the case with a laptop. You can try muting the audio from Volume control. You will still be able to record audio from the microphone.</p>
<p dir="auto">We recommend the following settings:</p>
<ol>
<li>Use Video/Audio Recording and Take Snap Alerts.</li>
<li>Configure upload so that WebCam Monitor can automatically upload files generated by alerts to an FTP folder.</li>
</ol>
<p dir="auto">You can log into your FTP account and view the uploaded files when required.</p>
<p dir="auto">If the possibility of detecting motion or noise is low, you can configure WebCam Monitor to run alerts periodically.</p>
<p dir="auto">If the volume of files you are expecting to receive is low, you can also use the E-mail Notification Alert to e-mail you a snap.</p>
]]></description><link>http://nodebbtest.deskshare.com/post/34658</link><guid isPermaLink="true">http://nodebbtest.deskshare.com/post/34658</guid><dc:creator><![CDATA[DeskShare_-_Support]]></dc:creator><pubDate>Sat, 08 Jan 2005 19:50:45 GMT</pubDate></item></channel></rss>
